early 85 944 side mirror replacement
I assume this must be a common issue because BOTH of my side mirrors fell out and smashed. I bought the car with just rubber backer pads. the rest looks fine.
is there a heat element involved? when I went to order them there seemed ot be options for heated mirrors and I though maybe there is some sort of heat element in behind the rubber or maybe some mirrors have heating elements ?
is there a recommended glue? the "Burco" replacements came with sort of a double stick tape but maybe I can use something better. the installation sheet suggested using both the double sided tape stuff and also a glue in the other areas. I have some sealant but I don't think it's really good at bonding. I thought maybe others have ideas.
Old 03-31-2023, 02:29 PM
My mechanic used RTV? Also there is a convex one available for the right side that wasn't oem.
Old 03-31-2023, 03:29 PM
The mirror glass is mounted to the rubber and the there is a heating element embedded into the back. The complete mirror assembly has three snaps that attach to a metal plate. If you go onto ebay you can find some good pictures of mirrors in various states of disassembly. Good luck.
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 04-01-2023, 01:27 PM
I guess if the heat element is in behind the rubber pad then all i need to do is worry about the mirror. I was wondering if some mirrors had the heat element combined into the mirror itself, similar to a rear defroster.
looking through ebay pics and such , it seems the rubber pad has a connector on the back.
If the heat element is in the rubber pad which I'm assuming is the case, then I suppose any glue or the two sided sticky pad may work as an insulator and reduce the effect of the heater. perhaps some glues will conduct better, Silicone might be a pretty good insulator.
I didn't get to see what was there originally I just have rubber pads there but I guess no wire connections either.
no point taking the rest of the mirror apart, I assume.
Old 04-03-2023, 09:20 AM
