Headlight wiring connector / harness
[ '87 944 NA ]
I have the following list of parts for the headlight. I’m just interested in basic connections.
911-631-108-00-M671 Flosser brand
https://www.pelicanparts.com/More_Info/91163110800.htm?pn=911-631-108-00-M671&bc=c&SVSVSI=0757
This has bare wire ends at one end that must be soldered onto a plug. I'd like to know if the plug is available new - i.e. what part number works for this? Or do I need to re-use the old part?
I also note :
944-612-035-00 Wiring harness
https://www.pelicanparts.com/More_Info2/94461203500.htm?bc=c&SVSVSI=0757
It'd be nice to see a photo of this.
812 971 970
https://www.pelicanparts.com/More_Info2/821971970.htm?bc=c&SVSVSI=0757
I think this is the white plug - not sure if it is with or without electrical connectors. Is this the plug on the headlight terminals?
87 944 NA
Old 05-15-2023, 08:40 AM
