Angry tranny problem
I bought a used 944s tranny to replace the bad one in my 85.5. When i went to put the coupler on the input shaft of the tranny it will only go on 2 1/2 inches. Upon inspection on the input shaft it appeares that the splines were not cut all the way as the is about 1/16 inch of metal behind the splines.
I have tried 2 different couplers with the same result and both will slide all the way down the input shaft on the original tranny.
Has anyone seen this type of problem before?
I spoke to the guy i bought it from and he said he had no problem getting the original coupler to slide on all the way. Unforenutely he threw it away figuring I did not need one.
Dave
Old 06-07-2003, 11:43 AM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
that is odd, I have a 944s2 tranny on my early 85, it went on just fine. That sucks man.
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 06-08-2003, 03:47 PM
Well after doing some modifications I was able to get it in. Just got back from a 30 mile test run and everything seems to be ok with the exception that it looks like i have a leak from the oil pan.
oh well, at I have a car to drive now!
Old 06-08-2003, 05:10 PM
