Send a message via Yahoo to neildeshpande
<944> VW Lock Cylinders to Rekey Car?
Gruppe:
The lock cylinders on my car are mismatched and I was wondering if the VW cylinders would work. I was told by the Porsche dealer parts guy that they were the same. Porsche wants $800 for a set of matched locks! The VW online sources have it at $10/lock!
Anyone have any experience with this? Thanks!
Neil Deshpande
Old 06-02-2003, 08:09 PM
wow that would be awsome!!!!
I need all locks/keys too
02 dodge quad cab 4x4
02 vw jetta tdi
03 honda rancher
Also owned,renault 177,alfa alfetta 1.8,alfa 33 td,89 grand am,jeep cherroke,suzuki sammari,gmc jimmy,tracer,grand carravan,astro van,73 240z,91 cirrus,95 ford f150 4x4,01 dodge quad cab,and a firebird
Old 06-02-2003, 08:13 PM
944turrboo's Avatar
hey let me know about that as well.. i need some new locks. i got mismatched ones.. well the right side (passenger door and glove box are the same) and the trunk driver side and ignition are differnt then the right side...
When life passes you by.. DOWN SHIFT!
Old 06-03-2003, 09:53 AM
Doesn't take much to have a locksmith redo all the locks. Choose the one you want to match to, usually the ignition, remove the other locks and take them to a licksmith. I did a number of years ago for a 924, watched the guy carefully and learned how it was done...relatively simple, I think it cost me about $25 for both doors and the rear lock. When I got my 944, one of the locks actually had a broken screwdriver blade in the passenger door lock!! I removed them and within an hour had all the locks the same. Just remember when you remove the tumblers, make certain there is a key inserted. Otherwise you will be "surprised" by little parts and springs flying in all directions.
Bob S. former owner of a 1984 silver 944
Old 06-03-2003, 01:07 PM
Bob:
I got a quote of $55/cylinder from the locksmith I called (recommended by the Porsche dealer) and of $5/tumbler (don't know how many I'll need to get all the locks to match up) at the VW dealer. I think I'll go the latter route. VW says they can do all locks, including glove box.
I'll keep the Forum apprised of what happens.
Neil Deshpande
1987 944 NA 5-sp
Old 06-07-2003, 08:12 PM
