911lnv87's Avatar
Selling our Silver Rose
Hi All,
After 2 year of restoring and fixing up everything we are now selling our 1988 Porsche 944 Turbo S “Silver Rose Edition”. 1/339 brought to the US.
My friend and I purchased this car two years ago as a "barn find" with the goal of restoring it.
Check out our Instagram @951_silver_rose
Key Details: Mechanical Condition: 10/10 Interior Condition: 9/10 (perfect dash) Exterior condition: 8/10 Title: Clean Miles: 94,700
Maintenance: April 2024: -Timing belt -Water pump -Timing belt rollers -Front engine reseal -Engine fuel line -Engine return line -All new silicone vacuum lines -Injector clean up -Motor mount -Fuel hose to pump -Fuel filter -Steering shaft -Spark plugs -Distributor -Oil and filter change -Adjust throttle -Brake, transmission and coolant flush/change -Alignment -Rearrange and organize wire harness -Clean manifold and reseal -Factory suspension tuned for road use
March 2025: -Crankshaft speed & reference sensor -Temperature Sensor -Coolant Temperature Sensor
May 2025: -Turbo Rebuild- - O-Ring - Oil Dipstick Tube to Oil Pan - O-Ring - Turbocharger to Support / Turbocharger to Lower Oil Line -Intake Manifold Gasket -Evergreen turbo rebuild -Misc exhaust hardware -Coolant -Temperature Switch (Timing belt re-tension, hood struts, and complete oil service done at same time)
June 2025: -Replaced intercooler boost pipes (identified the left-side boost pipe as split on the bottom side) -Replaced throttle position sensor
Non-mechanical work: -Seats re-upholstered -Wheels polished and ceramic coated -Paint refreshed (certain areas resprayed, and entire car paint corrected) -Full interior refresh (New clock, plastic fittings, leather reconditioning, cigarette lighter, Glove box stop, miscellaneous switches, sunroof motor, carpet cleaning and extraction) -All exterior lights replaced -New Shifter mechanism/bushings from only944 -New Sunroof seal
Included in sale: -Spare tire -Service record spanning cars life -Tool kit/pump
You can see it on the PCA.org or on our Instagram about the car.
Do not hesitate to share with good people as this is where this car shall end up.
Porsche 944 Turbo - Graphite Metallic - 2.8L - 1986 DD
Porsche 944 S2 Cabriolet - 1990
Porsche 944 n/a - Dark Blue - 1988 - Sold
Old 10-07-2025, 09:08 AM
911lnv87's Avatar
I notice i did not put a selling price.
Our price is $42,500
Old 10-09-2025, 07:26 AM
Yikes.
Old 10-29-2025, 07:22 AM
911lnv87's Avatar
I am not sure in understand your comment "Yikes" the car went through a full mechanical work, interior is near perfect, and this is a Silver Rose Edition.
Old 10-29-2025, 07:30 AM
Glws!
Old 10-29-2025, 07:33 AM
911lnv87's Avatar
I appreciate Dr Truth
Old 10-29-2025, 07:34 AM
there is a section for selling cars.
https://forums.pelicanparts.com/porsche-cars-sale/
Old 10-29-2025, 02:09 PM
911lnv87's Avatar
Car has sold and going to a great home
Old 12-02-2025, 01:20 PM
