Balance belt
1989 Porsche 944 2.7 lux
The balance belt as snapped. timing belt ok.
Does engine get damaged when its been run with balance belt snapped.Thanks
Old 05-14-2023, 02:35 AM
Not in the short term, but long term running without the balance belt causes damage due to vibrations (e.g. fuel rail cracking, oil pickup tube cracking). Fix it soon and you will be OK.
Good luck, George Beuselinck
Old 05-14-2023, 05:12 AM
If you are fixing a broken belt I'd say its time to replace all the belts. I believe its recomended to replace the water pump with the belt changes but I didn't.
Good luck,
John
John
1986 944 NA Black on Black
1966 Cobra Roadster Replica Silver no stripes
Old 05-31-2023, 11:08 AM
