-   -   CV dimensional info requested (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/114171-cv-dimensional-info-requested.html)
vissoctl 06-09-2003 12:42 PM
I'm looking for some cross reference CV information. Perhaps one of you can enlighten me.
I need a CV with these dimensions.
Body OD = 100 mm
Body Depth = 33 mm
Bolt Circle = 6x8 mm on a 86 mm circle
Splines = 27 mm OD with 25 teeth
I got these dimensions second hand, so the depth could be off by a mm and the spline count and diameter could be off by one.
This is a typical bolt up CV. What I'm finding is non typical of the one I'm looking for is the spline count.
If anyone knows of a Porsche or VW or BMW, etc that uses this joint (and inner vs outer), I would be a happy camper. FYI, the vehicle application for this joint is a Merkur XR4Ti.
Thanks,
Tony Vissoc
