Fuel pressure test kit
I think I'm running rich and want to test my fuel pressure. Is this cheapo kit sufficient to do the job or is there a better alternative? Thanks.
https://www.amazon.com/gp/product/B0B23XM99Z/ref=ewc_pr_img_1?smid=A1Q7LK027197Q0&psc=1
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
That should do the job just fine.
Good luck, George Beuselinck |
Yes and it even includes the needed M12x1.5 connector.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
Is it one of these?
Thanks for the help. My pressure tested within the specified range, but surprisingly a bit on the lower end. No leakdown after 20 minutes.
I replaced the fuel filter since it's cheap and easy. I may retest to see if there was any change. The pump was replaced by previous owner and does not look like a genuine bosch but seems to function as it should.
