1984 944 No Spark
Having an issue getting my car to start. It turns over but doesn't fire up at all. Before it stopped working, I installed new headlights and a new DME relay by Focus 9. I was also having an issue where the hatch wasn't closing properly because one of the pins broke so it was left semi-open. This meant that the interior luggage light and dome light were on the entire time I was gone fishing. When I got back after 3 days, the battery was around 11.6 volts and the car wouldn't start - thought maybe because the battery was dead. Recharged the battery and still the same issue.
Tach doesn't really bounce when I try to turn it on - it only bounces a little bit when I take the key out. I took out the fuel line going towards the injectors and fuel came out when I tried cranking it, so it's a spark issue. Tried pulling out one of the electrical connectors to the injector and still no luck.
Any ideas? Is it possible I shorted something out when I installed the headlights or the DME relay? Or maybe the coil or speed/reference sensors broke?
Old 08-01-2023, 10:38 PM
Always best to start with a DME relay jumper. Or maybe a peek at the timing belt, see if the rotor is turning.
Then maybe a test light on the coil, see if you are getting the negative pulses.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 08-04-2023, 04:57 PM
Solved! The wires to the crank sensors from DME was worn down and causing it to short itself.
Old 08-07-2023, 03:36 AM
