-   -   Using 16 X 9 911 Fuchs on an 951 (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/11443-using-16-x-9-911-fuchs-951-a.html)
Mac 01-28-2001 07:47 AM
I would like to swap my 16 x 8 rear Fuchs to the front and then use 16 x 9 (911 Fuchs) for the rear , did anyone do this combo on a 86' 951 .
I now the correct backspacing for the 86' 951 is ,front 4.92 " and rear 4.42" .
Blackfoot 01-28-2001 08:52 AM
i don't know if they would fit (i suspect they would) but have you any idea how much 9" fuchs run?
cachinggggggg!
Lawrence Coppari 01-28-2001 10:24 AM
Not sure they would fit.
1.2gees 01-28-2001 07:49 PM
I used 8 inch 911 fuchs on my early 944 NA, and my 17s (by 9) with the early offset fit on an 86 951, so you should be OK.
Don't even think about it in the front though! Offset is way off...
Ahmet
It's all the driver...
