Pelican Parts Refurbished water pump woes…..
I replaced the water pump on my 89 auto lux with a refurb from pelican parts (part E-106-021-24X ) it was a rebuilt 86 model and the impeller was slightly different to the one I took out..
I had it installed and developed some overheating problems, I posted here and got some good ideas as to what to check, thermostat, radiator , belt tightness, etc..
However all seems ok, the shop is now saying that it might be the water pump itself…
Not sure I buy that line yet, but the are going to put a new one in to test it.
Before I start shouting at them, have any of you ever noticed difference with the water pump impellers? And does this problem ring any bells for anyone? Could I have received the wrong water pump by mistake? (The box was clearly labelled as rebuild 86 for 89 and S2)
Regards,
Guillaume Field
1989 944 2.7 Auto
Old 06-11-2003, 01:08 PM
Roger Hall's Avatar
I have heard when replacing the water pump there is an upgrade recomended. So the difference may be correct.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 06-11-2003, 03:01 PM
this changed in 89 (it's the big bore block) and has the same part number as the S2 3.0L water pump
Tom
Early '85 944
Old 06-11-2003, 04:23 PM
The correct water pump fits the 89 2.7l 944 NA and the 944S2 ONLY
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-11-2003, 05:33 PM
