Author of "101 Projects"
Wayne 962's Avatar
Pelican Parts WOW - Smokin' Deal on Mahle Nikasil Big Bore Cylinder Kits (2.5/2.9/3.5)
I just got a sale notice from one of our suppliers, offering some smoking deals on these piston & cylinder sets from Mahle. They appear to be clearing out their inventory. I bought mine last week from Andial for well over $3K, my cost!!! These are now offered at about $1000 off of retail. If you know what these are, then you know that these are smoking deals, and they will be good *only* while supplies last. Okay here they are:
2.7 liter to 2.9 liter 93mm Mahle Nikasil Piston/Cylinder Set, for CIS Injection, 9.2:1 Compression Ratio $2495 SALE (reg $3655)
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=PS93-001
2.5 liter 86mm Mahle Nikasil Piston/Cylinder Set, for Carburetors / Mechanical Injection, 10.3:1 Compression Ratio, for 70.4mm crankshaft - 911 IMSA-GTU legal $2595 SALE, reg $3595
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&view_records=yes&mh=20&uid=default&description=PS86-001
SMOKIN DEAL:
3.2 to 3.5 liter 100mm Mahle Nikasil Piston/Cylinder Set, for Carburetors / Mechanical Injection, 10.5:1 Compression Ratio $2595 SALE, reg $3699
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&view_records=yes&mh=20&uid=default&description=PS100-001
Again, I only have access to a few of these at these prices!
-Wayne
Old 06-13-2003, 01:24 PM
Wayne 962's Avatar
I also have these sets. Call Tom at 1-888-280-7799 (ONLY TOM) extension 221 if you wish to buy one of these:
PS98-007 3.0 to 3.2 liter (98 mm), 7.5:1 911 Turbo thru 77 $2695
PS100-005 3.3 to 3.5 liter (100 mm), 7.0:1 911 Turbo 78 thru 92 $2795
PS100-008 2.5 to 2.8 liter (100 mm) (Stroker Engines) 944 Turbo $1100
PS100-010 2.5 to 2.8 liter (100.5 mm),(Stroker Engines) 944 thru 88 $1100
PS102-001 3.6 to 3.8 liter , 102 mm bore/109 mm sleeve, (Machine In) 12.5:1 Carrera (993) 95-98 $2995
PS102-002 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 11.3:1 Carrera (964) thru 94 $2895
PS102-003 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 11.3:1 Carrera (964) thru 94 $2895
PS102-009 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 9:1 911 Turbo 93 thru 94 $2895
PS102-010 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 9:1 911 Turbo 93 thru 94 $2995
PS102-011 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 8.5:1 911 Turbo 93 thru 94 $2895
PS102-012 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 8.5:1 911 Turbo 93 thru 94 $2995
-Wayne
Old 06-13-2003, 01:39 PM
