944 S2
944 S2's Avatar
944S2 AC needs a charge
Bought some AC Pro to charge my system, but the low pressure fitting by the compressor is too big. Is there an adapter for this?
Old 09-07-2023, 01:36 PM
The high pressure fitting is bigger than the low pressure fitting.
Early '85
Old 09-07-2023, 05:03 PM
Have you converted to R134a?
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP
Old 09-08-2023, 05:56 AM
944 S2
944 S2's Avatar
Car has been converted before I bought it. Current configuration: The large fitting (red cap) located by the compressor (Low pressure). The smaller (blue cap) is by the drivers strut. Perhaps they were put on backwards? Is that even possible?
Old 09-08-2023, 05:41 PM
944 S2
944 S2's Avatar
Old 09-08-2023, 06:05 PM
william_b_noble's Avatar
look in hte manual to confirm which hose is LP and HP, and make sure the fittings are right - I've converted several cars but none are nearby as I write this so I just don't remember. You can get enough R134 into the system via the HP fitting with the car not running that the system will start, and you can hook up your gauges to see which side is which - if it's backwards you will know right away. Note that with 134 you really do need gauges to do this right, it is very hard to just watch the sight glass as you could with R-12
Bill
www.wbnoble.com
Old 09-08-2023, 10:54 PM
Yes, it is quite possible. Both fittings on an R-12 system are identical.
Early '85
Old 09-09-2023, 07:34 AM
944 S2
944 S2's Avatar
For sure the low pressure is next to the compressor. Are you saying it’s possible to fill with the High pressure side with the car not running?
Old 09-09-2023, 01:00 PM
Buy this:
https://www.amazon.com/dp/B08BF3S33Q
Has everything you need. Put the red connector on the blue hose & vice versa.
Ideally, of course, you would fix the service port screw-up on your car. Might not be easy as the adapters may have been installed with loctite.
Early '85
Old 09-09-2023, 04:43 PM
