Camshaft Bolt Torque To Yield?
Hello, I am just finishing up work on my 951 (camshaft reseal, some other misc stuff) and just noticed someone somewhere mentioned that the camshaft tower bolt is a torque to yield bolt? Is that true? I did replace the bolt but had to remove it during assembly to check that I placed a seal properly, so I technically torqued it twice?
Old 11-24-2023, 10:53 AM
That's crap... where did you read that?
Old 11-24-2023, 11:38 AM
The WSM doesn't mention it (only to replace with the later 12 point if the sprocket uses the older hex head bolt), and I assumed 65Nm was below the grade 10.9 bolts yield point. I saw it at https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/525640-how-destroy-your-camshaft-5-less-easy-steps-pics.html#post5175619 and https://forums.pelicanparts.com/porsche-944-turbo-turbo-s/1055368-single-use-fasteners.html#post10790793.
Old 11-24-2023, 12:40 PM
There are no TTY bolts on any 944.
Old 11-24-2023, 02:21 PM
