1988 924S Automatic ATF Lines
I am in the process of replacing the auto trans damper in my 1988 924S and I cannot find where to disconnect the ATF lines so that the torque tube can be moved back. Any help would be amazing.
Old 12-05-2023, 11:18 AM
I'm going to suggest that you cut the lines in a convenient place (I would use a tubing cutter like plumbers do) and reattach them using fuel line and hose clamps (since those lines are not under pressure.)
Old 12-05-2023, 12:35 PM
Disconnect them at the banjo fitting bolt to the automatic transmission / transaxel.
If you decide to replace the rubber hose part make sure to use stainless clamps and hose rated for ATF.
Old 12-05-2023, 01:13 PM
