safe bet?
hi im considering buying this guy's used tranny from a 1986 944na to put in my 1987 944na.
I emailed him and his response is attached here. My question is: WHAT are the chances that this tranny is in good working order based on how its been stored? will it fit my car? how many miles should a tranny last that has been driven nicely? Would you go for this one or a rebuild of your own tranny? Here is his response: Howdy, here is the deal. I bought the car years ago for the nose, I had bought a 1988 with 41k miles that had a light hit on the right front corner. When I got the 88 back I found that the parts were outrageous to say the least. So that is how I got the 86, I bought it for parts. I took the nose and fixed the 88 and the 86 sat inside the storage building out of the elements because it had a mint black leather interior, for years and years till I finally took it all part about 2 years ago and got rid of the shell. When I got the 86 parts car it was hit down the left side, the drivers door and the left rear quarter was damaged. I drove the car my self from the building that It got delivered to over to the storage building about 5 miles away, where it met it's demise. That was in about 1992 and from what I can recall the trans felt fine and shifted good with no noises. It has been inside out of the elements the whole time I had it. It's still full of the original oil. |
I wouldn't have any problem using it if it's full of oil the seals should be ok.
Matt |
A transaxle doesn't really get affected by the "elements", but I still think this would probably be a good buy, (assuming the seller is honest) since the car only had ~40k miles.
Make sure you don't overpay him, however I'm sure your transaxle experiances will turn out better than mine! If I had a choice, I'd try to buy from somebody who you can physically see, and not just mail a check to. Used transaxles can usually be had for $300-650 for the 944 NAs, but this may be worth over that, since it's from a low milage car. Ahmet ------------------ It's all the driver... |
ahmet
the used tranny has 86K on it. how much would you pay? thanks |
Depends on how badly you need a transaxle, and how soon.
Personally though, probably up to $500, if I needed it really soon, if not finding one for ~350-400 isn't impossible. Ahmet ------------------ It's all the driver... |
i know some of you guys, especially ahmet, have bought some used tranny's before. how long do they usually last?
nevermind some guy just out bid me and bought the thing for $601
dangit! |
