Question early '85 sunroof problem
I've read numerous articles on later model sunroof repairs, but can't seem to find much on the earlier ones.
Here's my situation:
- cables are stuck in the fully extended position...
- switch works and you can hear the motor turn...
- nut on back of the motor spins when the motor turns...
- cables in roof do not move at all...
- can't turn motor by hand to lower cables... (tried to turn by inserting screw driver in slot on the nut on the back of the motor)
- had to cut headliner, remove bottom of cable boxes and manually release fingers from the roof.
Any thoughts???
early 85 944 na
My water cooled flat six is in my motorcycle...
Old 06-23-2003, 10:31 AM
SoCal Driver's Avatar
Change it to the newer two gear box system. If you can find one in a salvage yard get the removeable head liner piece too.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-23-2003, 12:05 PM
