968 engine in 944
Is this possible/easy to do? I read that someone did it...and it works great+ its fast
------------------ 85.5 Porsche 944 |
It's an interesting idea, but I think probably it would be more sensible to just buy a 968, unless you can do all the work yourself.
------------------ Former owner of a 85.5 Porsche 944 Currently own a 95 VW Jetta. |
But the engine is basically the same...not much would have to be done right?
how about the 968 turbo, very rare but some around.
I have no idea how hard it would be. I'm sure it's possible though. It would be pretty cool. Sorta like an S2 but better.
In a recent issue of "Excellence" there was a story on how to put a S2 engine in a 944S. I believe the same swap would work on a standard 944. Good luck!
Jon- |
This upgrade would be pretty expensive to perform, considering nothing is interchangable between an 8v 944 NA engine, to a 16v 968 NA engine. NADA! You've got to get all the wiring, computer controls, etc, etc, etc...
It's do-able, but doesn't make sense, unless you get the complete 968 engine and all it's accessories for next to nothing (ain't gonna happen). Well, to justify it, I think you'd already need a new engine in the 44 to start with! Labor would cost a lot too, but as far as the big stuff bolting up, there won't be a problem. So yes, easier than the usual engine swap, but could turn out way too expensive/hard for somebody with little experiance. Ahmet ------------------ It's all the driver... |
http://www.968.net/modifications/images/968_engine_in_a_944.jpg
Looks nice. But as 1.2gees said, It will be some work... /Magnus |
968 and 944s2 engines the same.. even the 944S with only diff. displacement..my0.02 cents..
Raf,
the total production run of the 968 turbos were 11 or 12. I remember wanting to buy one a year ago and found one in germany that had been raced. It had 79k kilometers and looked like it had been driven in the desert, and hit a couple times. Asking price was a meare 40k + shipping. |
sorry Raf, I wanted to say that to AMC.
or a 944 turbo on it... |
