Eleg's Avatar
Cool Need A/C!
I was driving with the A/C on the other day (although the A/C has not been working for about a year or more).
I had the button on and I noticed my battery had more drain than normal (hand was lower). I turned off the button and the hand went back to its regular place.
So, the button was replaced last fall (the original reason for no A/C). Now i'm pretty sure that the button is fine.
When I turn on the A/C I can hear a little "tssss" sound.
Does this sound like it needs a recharging?
Anyone else experience this?
PS: I know this topic has been beaten to death.
Old 06-24-2003, 10:07 PM
If there is more battery drain than normal, you probably need a new clutch. The clutch is an electromagnet with a long winding of fine wire in it. The wire is insulated by a coating. In time the coating disintegrates and the wire shorts on itself effectively shortening its length. Because it is shorter there is less resistance so more current passes and it also gets hotter. It's a vicious circle. You might need a new clutch.
Check the resistance of the clutch. Engine off. Place ohm meter on lead to clutch (there is a plug in about 1 foot away) and the other on the compressor. You should read anywhere from 3 to 5 ohms. If it is less, what I said above holds.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 06-25-2003, 04:02 AM
The additional current draw may be due to the fact that both radiator cooling fans are running at high speed, the compressor clutch is energized, and the A/C blower is running.
One thing that may help to reduce the voltage drop is cleaning your battery terminals, alternator connections, and ground connections.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 06-25-2003, 08:48 AM
Eleg's Avatar
The drop in battery power is minimal. I just noticed that the battery hand was slightly lower than usual. I had the battery replaced a couple of months ago so it caught my eye.
Old 06-25-2003, 11:58 AM
Roger Hall's Avatar
The hissing noise is probably normal. What year and model is your car?
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 06-25-2003, 02:35 PM
Eleg's Avatar
It's an 85 late 944.
Old 06-25-2003, 04:37 PM
Roger Hall's Avatar
Scott R or Wolf1 are more qualified to answer this. I have never worked on a 944 but you should have a sight glass on the receiver/dryier. Its a round glass window about the size of a large pencil eraser. If you can see alot of large bubles then the charge is low.
Roger Hall
81 924 N/A
Old 06-25-2003, 04:58 PM
