Behind the Sun
944 muffler hanger source
Is the rear hanger at the end of tail pipe available?
The U shape bracket with bolt holes that attaches to the rubber buffer?
It seems like it only comes welded to the mufflers and not sold individually
I need one for a custom muffler I'm fabricating
Any pointers appreciated
Old 06-06-2024, 05:33 AM
Yep, not available separately.
If you are fabricating a muffler, fabricating a bracket should be relatively easy.
Good luck, George Beuselinck
Old 06-06-2024, 05:48 AM
Behind the Sun
I wanted the original look and fit.
There are mufflers on ebay for cheap. I may buy one and harvest it
Old 06-06-2024, 06:03 AM
If you find one on ebay, or maybe in the parts book,
how about we all look at the picture ? I'm thinking maybe there is a way to fab one that looks OEM.
Old 06-06-2024, 12:35 PM
MW,
yes, that is possible.... I wonder why OP wants to have a "original look" in the area where it's hard to see that "original look", unless you're sitting or laying down.
I have "home-made" heat shield on right engine mount and don't care that it doesn't look like original one.
Old 06-06-2024, 03:05 PM
The newest of the noobs!
grendiers's Avatar
I boogered one up for my 951 about 6 years ago. Thought it would last a day! The top bracket is welded to a piece of exhaust tubing. And a hose clamp tightened it to the tip. Ugly but functional!
Old 06-06-2024, 03:34 PM
Im wonering if this stuff might eb good. Por 15 generally makes good rust products, this is good to 1200 degrees F and comes in grey..
https://por15.com/products/high-temp
I had another one I used on a new muffler system it wa a high temp stainless steel heat paint but had to be sandblasted or acid etched first , then cooked on, in an oven or by just running it and allowing it to heat cure.. It looked pretty OEM I thought. It had a lot of warnings on it and may be one of thoise banned substances..
I'm sure those gold colored things on Ebay will rust very quickly.
Old 06-07-2024, 12:12 PM
Those are for before and after the cat in the middle section of the exhaust. The rear hanger by the rear of the muffler is a lot different. It is attached to the tail pipe.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 06-07-2024, 02:58 PM
