-   -   Trying to remove thy fenders! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/11632-trying-remove-thy-fenders.html)
jacobss 02-18-2001 06:37 PM
Well I am trying to remove a set of 944 fenders from a parts car with no luck. I got all the bolts on the top down the hood line, the one in the head light bucket and the one down on hte bottom of the fender by the door. What am I missing here??? I can't get these things to come off. Porsche seemed to like using chassis calk, or glue of some type. Any suggestions or diagarms would be helpful.
Thnaks, Stephen
RaF944 02-18-2001 07:36 PM
If I'm not mistaken, The fenders are also glued with adhesive. I Heard that you have to be really carefull in removing them or you will bend them.
85.5 Porsche 944
lordgrommit 02-18-2001 08:48 PM
TO remove the fender get sharp knife and work it under the lip where the bolts came
out. Pull very Gently and the glue will seperate. and the fender will come off.
Matt
