-   -   Source for front turn signal boot (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1166484-source-front-turn-signal-boot.html)
barzee 09-02-2024 02:30 PM
I needed to remove the front bumper on my 1987 924S. Part of removing it is to disconnect the turn signals which are housed in the bumper. I noticed that the rubber boots around the front turn signal sockets are deteriorating.
http://forums.pelicanparts.com/uploa...1725312420.jpg
Does anyone know where I can buy new boots? If the boots are no longer available, what did you do to cover the socket to keep it dry?
rhett 09-02-2024 05:04 PM
Hi, these are no longer available from Porsche, but over here in Europe there is company that has re-manufactured them. here is a link...might help?
https://partworks.de/partworks/en/15323/1x-rubber-grommet-plug-for-porsche-924-944-turn-signal-headlight-cover-cap?c=986
TheSecondChris 09-03-2024 10:19 AM
There is a VW part that is similar and functionally the same and pretty easy to get.
171957911 is the part number
Monkey Wrench 09-04-2024 03:59 PM
kind of joking but if you buy a pair of heavy rubber gloves you can cut the fingers off and get 10 of them .. then use tie wraps and some sealant maybe.. you never see them and they keep water out right?
Did you hear about the guy with 5 penises?
- His pants fit like a glove.
