-   -   88 Base Tach/MPG Gauge (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1169552-88-base-tach-mpg-gauge.html)
knights89 10-29-2024 08:06 PM
Hi All,
I have an 1988 Base 944 - the build date is 12/87. Some items that were standard on the 1988 I do not have - ABS, Air Bags, etc. Apparently those items were not required until 1/88. Anyway my tachometer does not have the MPG gauge in it - I happened to see one at a car swap show a few months ago and picked it up. I did some investigation and have not come across anyone that has just swapped the tach out - they just swap the entire gauge cluster. Can I swap the tach? and if so - are there any additional connections/wires I need to run? thanks!
knights89 10-31-2024 06:17 PM
Anyone?
wwdwgs 10-31-2024 07:46 PM
It can be replaced:
http://forums.pelicanparts.com/uploa...1730429150.png
