AC fan switch issue - No 0 and 1 speed
Hi,
Recently the Speed 0 and 1 of AC fan do not work. Speed 2-4 are good. I have replaced another used resistor but not solve. I doubt the switch inside climate control unit but don't how to disassemble. Could I use a volt meter to test voltages on the plug to reisitor? Which terminals related to speed 0 and 1? Thanks Kayhttp://forums.pelicanparts.com/uploa...1730392027.jpg |
http://forums.pelicanparts.com/uploa...1730400303.jpg
This snippet of the wiring diagram should help you figure it out. |
You can clean the little bimetal thermal switches on the fan resistor module in the blower motor assembly. Hold them open with a toothpick and drip some vinegar on them.
It can also be the switch on the climate control head, they do fall apart. |
Thanks for advice. If I test the plug (shown in the photo of first post) with voltmeter, connecting ground and each termials one by one? 5 termials correspond to speed 0-4 ??
Testing with a DMM might not be definitive, you might see continuity under no load and with any significant load it could go away. I would test with a test lamp, maybe a headlight bulb and not a little pen-type test lamp. This is to simulate the blower load which is on a 30 amp fuse (a lot more than a headlight bulb).
If a DMM is all you have you can try it, if the circuits are dead they are dead. At the resistor block connector end it looks like socket 5 is ground and 1-4 should get power with the fan switch in the relevant position, but numbered the opposite way. Socket 1 = fan high, Socket 4 = Fan lowest. Check each to chassis ground and also to the ground socket. If it looks OK I would test again with a headlight bulb but make the test lamp connection and then flip the switch to avoid a small arc. Sounds like a pain but a circuit failing under load is exactly what I see with switches like the blower switch, they might test good with no load and fail with a good load. I have also seen the switch crack apart inside the control head. |
I drop the resistor into vinegar to remove rust. It works.
I figure out how the resistors working with speed 0-3. All resistors are good, but the little copper contactor in one of two switch is open. It causes no current in sp 0 and 1. I bend the copper piece but insuccess. Could I drop a glue to hold them together? It raises a question : what is the purpose of these 2 switches?? "110℃" marked on the switch.. does it relate to temperature? http://forums.pelicanparts.com/uploa...1730647113.jpg http://forums.pelicanparts.com/uploa...1730647113.jpg |
Yes they break the circuit if they get too hot. I usually hold the contacts open with a toothpick and use vinegar to clean in between the contacts. It is hard to clean them when the contacts re touching.
| All times are GMT -8. The time now is 09:35 PM. |
