oil pressure gauge
1986 944T when I turn the ign on, the oil pressure gauge max's out to the top Is this normal?
Thanks, Rick |
No, your oil pressure sender has gone kaput. Replace it.
Good luck, George Beuselinck |
Does it act normal once running or stay pegged at 5 bar?
If so, the sender wires are setup backwards or you sender is bad https://www.clarks-garage.com/shop-manual/lube-03.htm
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
Don't know yet just put it all together and had replaced the sending unit with a new one Thought about the wires hooked up backwards, will look at that Don't want to start until this is fixed
Thanks, Rick |
tried swapping the wirers, still pegged Disconnected both wires and it still pegs Bad gauge, bad wiring or is this the way it is I did replace the wiring from the loom under the intake down to the OP switch
Thanks, Rick |
My oil pressure "broke" right after I serviced the oil/cooler (new gaskets/o-rings).
In the Fires of Hell.....
Something is wrong in your wiring. IGN on should have 0 on the gauge.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Got a short somewhere then or faulty gauge or you messed up the wiring.
Measure voltage at the gauge cluster plug, and start tracing wires back. Wiring diagram from the FSM is here; http://p914-6info.net/944%20Manuals.html
Anybody have the section of wiring diagram for the oil pressure gauge and idiot light from cluster to switch
Thanks, Rick |
Zombie
Have you carefully cleaned the contacts to the pressure sender...and checked the continuity of the sender wires?
My thought is that a pegged indicator due to switched wiring would be the same as a pegged indicator from a lack of continuity - so the easiest thing to start with (if you have not already done this) would be to simply go back and "super-clean" the contacts at the sender...switch wires at the sender if you still get a pegged indicator - then work back from there. Another obvious question...has the indicator always pegged throughout your ownership of this car - or is this something recent...and has this happened without any other intervention on the part of yourself or someone else servicing the car? Later Edit: And while I realize that this may be preaching to the choir...do keep in mind that a good cleaning of all major electrical grounds, followed by an application of dielectric grease to protect them...can solve all kinds of electrical gremlins! Last edited by OK-944; 12-21-2024 at 12:07 PM.. |
Check at the 14 pin connector:
https://rennlist.com/forums/924-931-944-951-968-forum/1176292-14-pin-connector.html
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
