Blown head gasket or stuck open fuel injector on 944?
I'm having symptoms of a possible head gasket.. I've read other posts about it and seen it can possible maybe be a stuck open fuel injector?
Rough idle sometimes at startup for a min or 2. I got a lot of white smoke come out from the exhaust maybe 3 times at start up in the past 3 months (I drive car 4 times a week) Car does not over heat, I do get coolant loss and only 2 times the coolant leaked from the bottom (hoses?) What symptoms do I look out for? What test can I do before I break the bank to get a head gasket job done lol. Any help or advice is appreciated. |
Shut it off during the rough idle and look at the spark plugs.
White sweet-smelling smoke is coolant steam. But the plugs will tell us a lot.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
I second Jfrahm.
Run a compression test.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
![]() Spark plug are fine, look normal. Not wet or clean. Compression test is interesting. 1-165psi 2-162psi 3-168psi 4-152psi What does this mean
Did you run a coolant pressure test? You could drain the oil and look for coolant in the oil. is there coolant (milkshake) in the oil filler cap or the radiator cap? regarding the low compression on #4 it is not too troubling since it is within 10% but you could run a leak down test. Was the throttle open all of the way when you ran the comp test? Did you have equal number of cranks on each cylinder when you did the comp test? usually 5 or 6...
White smoke doesn't sound like fuel. Last edited by djnolan; 11-14-2024 at 01:14 PM.. |
Compression numbers at a minimum should be within 10% of each other. Yours are about 10% difference from 168 to 152.
Agree with djnolan, coolant pressure test is the next thing. Compression test doesnt always show a bad headgasket, especially with a small leak, but is always a good place to start. If coolant system doesnt hold pressure, and there are no visible leaks, likely that pressure (and coolant) is going into the combustion chamber. Make sure your coolant tank cap is secure and holds pressure before doing so.
Thanks for your help |
I’m sure I cranked it around the same but I would do it again just to keep sure again. |
hello, the first step would be to rent a coolant pressure tester from autozone or other auto part store and to test the cooling system. The pressure tester connects where the radiator cap is, and has a pump to pressurize the system and a gauge to read the pressure. pump it up to 12 psi and watch the gauge to see if it holds at that pressure. it should hold for 30 minutes or more. if it is loosing pressure look for leaks such as loose hose clamps, fix and repeat the test. if it still doesn't hold pressure then it could be the head gasket.
here is an article https://haynes.com/en-gb/tips-tutorials/how-use-pressure-tester-find-coolant-leak if you don't feel comfortable doing this test yourself take it to a shop. Last edited by djnolan; 11-14-2024 at 03:31 PM.. |
could it be an oil-coolant radiator?
This would not cause white smoke to come out exhaust, but would cause oil/coolant intermix
Would require head gasket replacement and a bunch of "while you are in there" type work. Head refresh (resurface, valve seals, guides, valve job), timing/balance shaft belt + rollers, front engine reseal (if you have oil leaks), water pump, etc.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP Last edited by walfreyydo; 11-15-2024 at 05:35 AM.. |
Hi, also consider that if there is a coolant leak, coolant getting in the oil will rapidly damage the bearings if the engine is run. replacing bearings is considerably more difficult (or expensive) than a head gasket. so you should get to the bottom of this before driving the car anymore.
If you had a milkshake condition on the oil filler cap (or a lot of condensation) this would be a sure sign of oil in the coolant. for peace of mind you could drain the oil and see if there is coolant that will sink to the bottom. Last edited by djnolan; 11-15-2024 at 08:08 AM.. |
are you saying 12.0 dropped to 11.5 psi after 30 minutes? if so you don't have a coolant leak in the head gasket or elsewhere. 0.5 psi is within the margin of error or what would normally be lost.
Music to my ears lol. But why would I get white smoke occasionally? It has only happended 4 times in the last 4-5 months roughly. Maybe cause I didn’t use it for a week?
Condensation. Does the smoke appear right away or after some time?
When it happened , it would be right away .
