How hard to change out a battery alternator starter harness
I have to change it out and want to know if access is easy ? Also where best to get a harness?this is on a 92 968 coupe
Recommend getting the cables here, much higher quality cabling than the OE parts: https://www.dcmachinist.com/shop/porsche-cables/5
Access is not great, if you have a lift to get you plenty of space to work under the car, your life will be a lot easier. |
Where does the line from positive cable that goes into firewall towards passenger compartment go?
| All times are GMT -8. The time now is 12:54 PM. |
