Loose wheel
I just purchased 4 Michelins at Costco (great deal. After rebates I'll pay just $450 for 4 new shoes installed) and as they put the car up on the lift, they noticed the left rear wheel wobbled back and forth. They refused to mount the new tires until I fix this problem.
I've had the car for 8 months and the thing drives and runs great. I've noticed no handling problems at all. I know this topic has come up before, but I can't find the thread. I freely admit to be somewhat mechanically declined and will be at the mercy of a repair shop.
Any input is appreciated.
TIA
Old 07-03-2003, 04:08 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Sounds like a wheel bearing, and the car should've been very loose...
The bearings aren't going to be an easy job, if you don't want to mess w/it, just turn it over to a repeair shop.
Ahmet
Cheers!
Old 07-03-2003, 04:10 PM
macreel's Avatar
connecticutdan... first things first; be sure the wheel (hub)nut is torqued to spec (ie, a lot of Lb-ft - check your books, ~340 Lb-ft).
macreel
macreel
'79 924 (red)
'84 928S (copper)
Old 07-03-2003, 05:19 PM
Good advice, thanks guys.
I did some looking around. Amazing what pops up on the internet when you type in "loose wheel bearing" on google.
Now for a stupid question. What are the chances my wheel will fall off? The guy at Costco was very animated and said that I shouldn't even be on the road for that reason. From what I've read, I don't think the wheel is going anywhere, but excessive driving will cause friction and a worsening condition.
Old 07-03-2003, 05:30 PM
MikeCT's Avatar
Send a message via AIM to MikeCT
Ahmet
Is that just for the rear wheel bearings because I have a front wheel bearing making a clicking noise. I haven't checked the races yet but hopefully its just the bearing. I read in the factory manuals you need to heat the rotor to a certain temp. in order to replace the races. Approximately how much would it be to replace the races and bearings if I brought it to a shop?
edit: The place I would be bringing it to charges about $70/hr.
1984 944 N/A
1996 Golf Gl
Drive fast. Take chances.
If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields
Old 07-03-2003, 06:09 PM
TSNAPCRACKLEPOP's Avatar
(music) YOU PICKED A FINE TIME TO LEAVE ME LOOSE WHEEL......
(KENNDY ROGERS)
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-04-2003, 11:15 AM
