944 Windows Don’t Work
Before leaving for a short trip, I drove my 1983 944 all over. My windows worked flawlessly. Today I went for a short drive. None of the window switches work. The fuse looks to be good. I recently replaced all the window switches. When the window switches were faulty, at least one of the switches worked one of the windows. Weird that the windows worked, then after sitting, the windows don’t work. Any ideas?
I got it fixed. After repeated toggling of the drivers side switch, everything works now. The switch contacts must have become slightly tarnished while sitting. These switches are a weak point in this otherwise, fun car.
This is true (weak point).
It is also true that the PS switch keys off the driver's, so if the driver's switch dies, PS will also not work. |
