Searching for an Accordion Style Rubber Shift Boot
Does anyone have this style shift boot they would be willing to sell? Or does anyone know what the product name is / what model it came on / where I can get one?
https://forums.pelicanparts.com/uplo...1338848349.jpg It's an accordion style rubber shift boot (for ref if the image link doesn't work) |
Not a factory part...
I did a google search on "accordion style shift boot" and came up with a lot of hits. |
Early-mid 80's RX-7's came with the accordion type... not sure if they'd fit. If you're good at that sort of thing, you could probably design and 3d print a trim ring that would work with it.
if you can write or download the file you can print rubber parts or send them to a place that can.
https://all3dp.com/2/3d-print-rubber-is-rubber-3d-printing-possible/ it seems likely a boot from some other car could be adapted. Id look in a wrecker if there are any naear you these days. many of the makers puut an end to auto parts recycling by using lots of proprietary parts and changing their design frequently , this is unfortunately not beneficial to the environmet or the consumer's personal economics. |
That looks like the boot from an early 4-speed 924...
924RACR is correct: 477711271A
| All times are GMT -8. The time now is 02:35 AM. |
