MikeCT's Avatar
Send a message via AIM to MikeCT
Gas Cap Questions
How can you test if your gass cap is holding a vacuum? If the gas cap leaks is this / could this cause problems? Just wondering.
1984 944 N/A
1996 Golf Gl
Drive fast. Take chances.
If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields
Old 07-08-2003, 10:34 PM
I believe any place that does a smog check has the tool that can hook up to your gas cap and check if it's able to hold the right amount of pressure.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-08-2003, 10:43 PM
Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
Is a pressurised tank nessesary? My cap was rusted through and leaked on the hard corners. I noticed no difference when I got a new cap. (that dosen't leak)
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 07-08-2003, 10:49 PM
When you talk about the gas cap, presume you refer to the cap for filling petrol. You don't want a vacuum there it could cause petrol starvation.I doubt Positive pressure will hurt much unless it builds up too much to blow rubber hoses etc. The seal should be mainly to help prevent evaporation of petrol.
Old 07-08-2003, 11:07 PM
MikeCT's Avatar
Vacuum was not the correct word. I mean pressure from the tank.
1984 944 N/A
1996 Golf Gl
Old 07-08-2003, 11:18 PM
SoCal Driver's Avatar
It isn't the cap that is leaking. It's the short piece of hose that connects the filler tube to the gas tank propper. Also the small vent hose cracks and leaks too.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-09-2003, 01:30 AM
Here in the states the gas tank is sealed and the fumes are scavaged into the engine intake. So the seal on the filler cap is tested -- I think for a vacuum.
Old 07-09-2003, 01:32 AM
MikeCT's Avatar
How hard is it to get to the vent hose. I was looking through the factory manuals it says you need to take the side window out. Is there another way to do it?
1984 944 N/A
1996 Golf Gl
Old 07-09-2003, 09:33 AM
TCMdocs944's Avatar
Just read a post that says the quarter windows are exceptionally easy to remove.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-09-2003, 11:35 AM
You can bend up the inside trim panel but the best way to get to the filler cover is to do the proper thing and remove the side window or you may tear the trim.
I've cut my trim so it just slides under the inside of the window rubber seal and not over the edge of the body work. Stays in place nicely. Also have less problems re-sealing the window.
the most likely leaking point is the small vent hose. You can cut it and put a 45 degree copper tubing elbow in and clamp it. That way you don't have to drop the gas tank.
Old 07-09-2003, 11:58 AM
