Question Timing Belt
I'm getting close to 120k miles and the previous owner of the car said she couldn't recall whether there had ever been a timing belt change on the car. I asked a local shop about it and they said $600 for the timing belt and water pump. I want to try doing it myself, if possible. So, naturally, I have a few questions about the procedure.
First, how difficult is a timing belt change on a 944 turbo (does it differ very much from a 944 NA?)? And, how much more difficult will it be to replace the water pump while I'm at it?
Second, I saw this "Porsche Belt Replacement Kit" on ebay (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6763&item=2422774873 ) and was wondering if anyone has ever tried replacing their belts with that same or similar kit. Do these kits work well? Are there any other belts that will need to be changed besides what is mentioned in the kit? Will the "tensioning tool" in the kit work anything like the $400 Porsche tensioning tool?
Thanks,
Matt
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-08-2003, 10:58 PM
Baza's Avatar
My advise is, If you not comfotable doing it "pay someone" because if its not done right it will cost alot more than you saved (order of the bent valve). If you pay someone and it goes wrong they pay.
Always start with the cheapest option first
83 NA Gaurds Red ( Home at last)
Holden/Opel Vectra 2002
Old 07-08-2003, 11:15 PM
SoCal Driver's Avatar
Where in L.A. are you? I'm in Costa Mesa.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-09-2003, 01:34 AM
I'm in Rowland Heights (midway between downtown LA and Riverside)
'86 951 blk/blk
Old 07-09-2003, 03:04 AM
To replace the water pump you'll have to remove the back of the timing belt plastic housing. That means the crank pulley must come off. To get the crank pulley off, you'll need a flywheel lock and a cheater bar to get the bolt holding the crank pulley off.
There is nothing difficult about the water pump removal. Just don't break any studs off. The infamous snap ring for the thermostat can be dealt with much more easily with the pump removed from the engine.
Like someone else said about the belts. If you are not comfortable doing them, let someone else do them. If it breaks, it's expensive.
Reams have been written about how to tension the belt properly. People do not all think the same on that contentious subject.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-09-2003, 05:25 AM
Anyone know a good shop around Los Angeles that has done belts/water pumps on 944s and is not too expensive? I asked Mckenna Porsche how much they would charge for the timing belt and water pump and they said $1525!!! I definitely am going to do some searching around for a mechanic that can do it for a lot less.
Thanks,
Matt
'86 951 blk/blk
Old 07-09-2003, 09:27 PM
Baza's Avatar
I know Iam in Australia but with our dollar only worth $0.67 US this seems expencive as it only cost me $997.70 to have my water pump replaced and that was by a dealer.
Old 07-10-2003, 04:04 PM
