'87 944 AC issues - possible "amplifier"? Component location help please.
Hello to all the 944 Guru's -
My son bought his first P-car - an '87 944 - runs great but AC issues - it is a 134a converted unit by PO. AC worked great about a half hour and then quit. We put 12V to the clutch and it engages. We jumped the relay at 30/87a and nothing. We jumped the pressure switch on the dryer and nothing. Fuse 29 is good. Relay was replaced for the fun of it. Light on panel illuminates when AC is turned on. http://forums.pelicanparts.com/uploa...1755724379.png From the wiring diagram above - the points of interest are Connectors T63 and T31 in line from "Amplifier" to the low pressure switch, the amplifier and the "Additional Fuse Board" (fuse 3 and fuse 6). Where are these components? I really dont want to defile the wiring harness to chase wires if I dont have to. I read that the amplifier might be in the passengers floor next to door - we removed the glovebox and it is not there (only the radio amplifier) Any help is appreciated! Trey |
That is not the schematic for your year of car. Download the factory workshop manual and look over the correct schematic.
https://www.uriarte.dk/porsche944/garage/workshop.html 944 Workshop Manuals |
I think I read recently that someone got a bad new AC relay, designed wrong or built wrong. Bad in the box new. The dash switches also go bad.
The wiring diagram I glanced at (way different than pictured above) seems to show a High/Low pressure switch and a high pressure switch. I would track back from the clutch with a power probe. http://forums.pelicanparts.com/uploa...1755777613.png |
Thanks! |
Further down. Model year 87 starts on page 191. HVAC is on sheet 5, starting on page 207.
I am following this thread as I am having a very similar (if not the same) issue on my ‘89 Turbo. I initially thought I had a bad relay, but after further (and correct) testing, apparently that is not the case. I have not found much out there on the high pressure part of the LP/HP switch, only on the low pressure part of it. I bypassed the low pressure part by jumping pins 1-3. Can I do the same for the high pressure using pins 2-4?
| All times are GMT -8. The time now is 09:32 AM. |
