MikeCT's Avatar
Send a message via AIM to MikeCT
Oil Filter Question
Something I read in the Performance Products catalog said to punch a hole into the filter so that the oil drains out. Has anyone tried this? Do I just punch a hole in the top?
1984 944 N/A
1996 Golf Gl
Drive fast. Take chances.
If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields
Old 07-10-2003, 11:11 AM
SoCal Driver's Avatar
The good ones have a check valve in them and will not drain back.
Was suggested recently that you pull an old athletic sock over the filter and use it to catch the oil as you remove the filter. I think you have to loosen it a bit first.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-10-2003, 11:32 AM
MikeCT's Avatar
I'll try that thanks.
1984 944 N/A
1996 Golf Gl
Old 07-10-2003, 12:04 PM
ruechaos's Avatar
I've done the hole punch method twice now. Just remember to drain your oil first, then do it, else it could be a real mess.
-Tony
'84NA Engine, '87NA Brain/AFM/wiring
harness, all in an '87S Body....AND IT
RUNS!!! kinda...
Old 07-10-2003, 12:11 PM
