Escaping air
Ok when i turn off my car, hear a sound like air is escaping from somewhere, depressurizing. I want to know if its supposed to do this, or not. I bought the car about a month and a half ago and don't remember if it was doing this when i got it. Any help is good help. Thanks.
Is it the A/C system you're hearing??
Just a thought,
VT944 Brian 1985.5 944 Dodge Viper Blue on black/tan white face gauges throttle cam short shift kit |
Escaping Air
I dont really use my A/C because it doesn't work. So im not sure that it would leak if i dont use it.
Could be the cooling system. What level is the temp gauge running at -- which mark? I bet it's one of the fans. It's run a few minutes after you shut off a hot car to keep the hoses from expanding and possibly burtsing.
Please add the year and model of your car to your signiture in your personal profiles. Gets you better answers to your questions.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Is the shound a faint hiss, or is it loud???
Could also be a vaccum line?? And yeah, edit your profile to list make/year and mods done to the car. The more info, the better the replies.
Rawr
Its kind of loud, (loud enough to hear from 20 feet away) seems to come from right infront of the passanger seat (under the hood) anyone wanna tell me what is there that would leak air or something?
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
Battery?
the engine is there
*ducks*
84 944 Non Alcoholic |
rawr
hum... wouldnt be the battery since i dont think it would run if it had been leaking for 2 weeks..
There is not much other than the prussure in the cooling system that can "escape" from a just stopped hot engine for twenty minutes.
Could be a sticking valve in the AC evaporator as inside the car in the passenger foot well is where it is located. With out being in the car and listening we can only go on what you are describing -- or not describing.
Next to the battery in the tray area is a black plastic canister for holding vacuum, maybe it's leaking after you trun the car off.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
