 MSD 6 AL (where at?) I was wondering if anyone has installed an MSD 6 AL ignition box into their N/A 944? If so, where did you put the box and were you pleased with the results from it? I need ot buy a blaster 2 ignition coil and I was thinking new plugs might help. Thanks for the help. |
 I recently added a MSD to my car. I stuck it in by the battery, it was a tight fit. As far as power increase I can't really tell you because I added a turbo at the same time. It seems to work alright though. |
 I'd like to see a before & after dyno-comparisoin of any ignition upgrades on these cars. ;) |
 I was thinking on the strut tower right next to the cam tower but that would be a tight fit and it mihgt get real hot. |
 Also keep it as far away from the DME as possible... ;) |
| All times are GMT -8. The time now is 11:17 PM. |
