-   -   944 Won't Run with all 4 injectors connected (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1185372-944-wont-run-all-4-injectors-connected.html)
PrincessNara 10-24-2025 07:59 PM
I've been having an issue with my 87' 944 NA, it won't run with all four fuel injectors plugged in, i can plug in any 3 injectors and it'll work fine but the car dies the second I plug in a fourth one. I have replaced the fuel pump, pressure regulator and damper, injectors, and injector connectors and nothing has changed, I have also replaced the capacitor in the DME and tried two different ROM chips, any help would be appreciated, Thanks!
DrTruth 10-29-2025 07:23 AM
Time to look at the injector harness for shorts.
