which 944 to buy?
I have always wanted a 944. If I start to look for one what can be had for around $5000. I do have a 911 that I am in the process of rebuilding, but I would want some thing for everday transportation. I do not mind putting some work into the car.
If you shop around for a while you can find a lower mileage 944 or a slightly higher mileage turbo. Maintenance is the key. I just found an 86 Turbo with 72K for 7K.
'86 Guards NA 70K- driving 11yrs '98 Techno-Violet M3 57K- since 4/04 '55 MiG-15 UTI - Mach.97 -rebuilding '58 Cessna 175 w/GO-300 '98 Scarab Sprint, 4.3V, 62mph '92 Guards 968 (my girlfriend's) Gone... '82 Camaro Z28 1st car '84 VW Rabbit Cabrio & GTI '77 BMW 630 4spd sport bilstiens '84 POS Cavalier- drove to junk yard |
Non Compos Mentis
5k? A clean 85.5 or later NA. If you shop around, you can keep some change in your pocket for any fixes down the road.
Writer/Teacher
or, if you're into something lighter and quicker
, $5000 will buy you a really nice early 944
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
I knowvery little about 944's What are some of the things that I should be on the look out for?
When the timing belt was last replaced. If not changed in the last 30K miles/5 years or so, then it should be changed asap. Also look for whether or not the clutch has been replaced. Its a fairly pricey job. I'm sure some of the other guys here can chime in with more tips.
'85.5 944 Kalahari Beige/Brown 5-speed 76K miles color-matched fuchs SOLD |
