-   -   Low compression numbers due to valve, why? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/118976-low-compression-numbers-due-valve-why.html)
ilikemy944 07-14-2003 03:01 PM
Looking at a turbo, maybe.
Lower compression in one cyl. due to an intake valve... what would cause this, would it need immediate replacement?
SoCal Driver 07-14-2003 03:12 PM
What test was done to clearly indicate an intake valve as a problem?
Could be a scored cylinder/bad rings.
Roger Hall 07-14-2003 05:07 PM
Burnt, cracked, or bent valve could cause compression to leak. I am not sure about the 944 valve train but a broken, collasped, or cracked valve spring could also cause this problem. Alot of carbon build up can also prevent a valve from sealing properly.
SoCal has a good point though it could be the cylinder/rings. I would also suggest a bad head gasket. Head gaskets seem to be a common problem on these cars.
ilikemy944 07-14-2003 05:14 PM
It was a PPI so I'd assume the results were from a leakdown...
What exactly is a burnt valve? The car still runs fine, so I doubt it to be a bent valve... And wouldn't a bad spring cause real problems at high revs?
Roger Hall 07-14-2003 05:29 PM
I have never had either problem so I am not sure, but here is my understanding.
A burnt valve is caused when the valve becomes too hot, and the heat causes the valve to deform.
Bad springs should affect an engine at any RPM.
SoCal Driver 07-14-2003 06:33 PM
Only the exhaust gets "burnt". This is where there is a small bypass at the valve (cracked valve seat or a bit of debris like a lost washer) and the exhaust gases scours a bit of the seat and/or valve. this grows till there is almost no compression on the cylinder.
A leak down will tell you real quick if it's the valves or the rings/cylinder wall.
Having an intake leak is very rare unless there is something stuck in the seat. Then there could be a bit of burning but most likely predetonation of the intake gasses resulting in some serious damage.
