-   -   What should I do first? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/11919-what-should-i-do-first.html)
stray15 03-16-2001 06:44 PM
Well, my car is in desprate need of a paint job and wheels. The paint has a huge key mark on the drivers side, it was there before I bought it. There are a few small, small dents, not from me either. The front chin is all chipped and there is metal tape around the sunroof sealing it so it doesn't leak(from me http://www.pelicanparts.com/ultimate/frown.gif ). My cookie cutters are looking awful from corrosion.
So, I want some ideas. Should I save to get it painted first or should I get new wheels or get mine refinished? I was thinking of either sending my wheels to www.transwheels.com or buying a new set from them. I would be getting a discount from them because the company I work for has an account with them. Has anyone had any experience with them before?
Thanx guys
Porsche, Through and through
Tim
'83 944
lm6y 03-17-2001 07:51 AM
Tim, the cookie cutters look great with the rim part polished, and the center given the Blackfoot treatment.
I did it on my car, and it improved the appearance 100%. If you polish the rims, make sure you clearcoat them, or the brake dust will eat the aluminum, leaving pits in them.
Now for the real question. Can you get powdercoat in clear? When I do the other set of cookies I have, I'm going to powder coat them.
Leigh 13 03-19-2001 08:04 AM
Blackfoot...care to elaborate on your custom treatment?
Blackfoot 03-19-2001 08:29 AM
http://albums.photopoint.com/j/View?...nce=0&res=high
hoff944 03-19-2001 08:47 AM
What did that wheel look like before?
Blackfoot 03-19-2001 08:21 PM
it looked like a tsw hockenheim 17x8 wheel.
stray15 03-20-2001 11:36 AM
That looks good and all, but what about on cookie cutters, Should I paint the whole thing black or just redo the center?
Tim
'83 944
Blackfoot 03-20-2001 01:57 PM
everyone else will say just do the centers. you know what i will say.
it's all the color...
AMCPorsche924Powerhaus! 03-20-2001 02:14 PM
That tire is so short, is that what all 17 inch wheels have on them now?
awilson40 03-20-2001 02:38 PM
That rustoleum is great paint, but I wonder how it will hold up under the heat and dust of disc brakes??
Blackfoot 03-20-2001 03:06 PM
if i recall correctly it's a 215/35/17 tire. it was on my rx-7 when i purchased it in seattle last year. not happy with both the low-profile or the low-traction those tires afforded.
heat is no problem. as for brake dust, i don't know. it took less than an hour per wheel. but i'm experienced with paint, so it may take a bit longer for others.
[This message has been edited by Blackfoot (edited 03-20-2001).]
stray15 03-20-2001 04:15 PM
What about the whole rim getting powder coated black? Everything
Tim
'83 944
Blackfoot 03-20-2001 04:35 PM
i've heard powdercoating, like chroming, is a bit expensive. and believe it or not, i prefer a glossy or metallic black to the flat black that you get with powdercoating.
it's all the blackness...
stray15 03-20-2001 04:39 PM
You can get it flat or glossy.
Tim
'83 944
