TCMdocs944's Avatar
Exclamation Turd in the punch bowl
Damn PO.
This appears to be an audi? Fuel injector in my rail.
The size is the same, connections the same, length the same..only difference is no hat at the end.
Should I put it back in or get a genuine replacement? (think about it as if your spending your own money )
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-19-2003, 09:42 AM
TCMdocs944's Avatar
Think everything is ok if I just put a new hat on it?
Old 07-19-2003, 09:43 AM
Compare the spark plugs. If things are different, you should see it. If they all look the same and the car runs fine, I wouldn't worry about it.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-19-2003, 09:44 AM
SoCal Driver's Avatar
The hats and seals come as a reseal kit at most parts stores including Pep Boys.
The ones I've seen and others have reported on do not have the conical recess/counter bore that the OEMs do.
You can use a sharp large drill bit to fix the after market ones.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-19-2003, 10:58 AM
P.S. You did check the intake to make sure the hat is not stuck in it?
Old 07-19-2003, 11:10 AM
TSNAPCRACKLEPOP's Avatar
how do you know that you are not driving an audi with everything switched except that fuel injector?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-19-2003, 04:16 PM
We are driving Audi's. Just ask a 911 owner.
Old 07-19-2003, 05:00 PM
TCMdocs944's Avatar
TSNAPCRACKLEPOP how do you know that you are not driving an audi with everything switched except that fuel injector?
Makes you think doesn't it.
Yeh, I checked for the hat but its a nogo. I have been pretty meticulous about this tear-down and haven't seen it.
I examined it closer today and feel the spray may be 1/8-1/4 higher than the rest......Hmmmm doesn't sound that good.
Hey Snap check to see if your car has 3 audi injectors and one porsche. I'll swap ya
Old 07-19-2003, 06:27 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
is that cyllinder's spark plug different from the others?
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 07-19-2003, 06:35 PM
TCMdocs944's Avatar
Yeh, so is the piston
Old 07-19-2003, 06:39 PM
Writer/Teacher
CJFusco's Avatar
um. are you serious?
Old 07-19-2003, 07:11 PM
TCMdocs944's Avatar
Just kidding about the piston.
Actually
I seemed to have water infiltration into the number one and two. Odd FI was number two. The head gasket was in such bad shape I am not sure if I could really tell if it had anything to do with the injector or not.
Old 07-19-2003, 07:43 PM
