Is there any way of checking to see if the DME relay is good or bad?
How can i check to see if the fuel pump is working? Motor trys to turn over but won't start. Runs fine then all of the sudden it will just die. sometimes you can wait a while and it will start back up. Is there anything else i should check and how? |
I'd say you could run a wire from the battery to the fuel pump to see if it runs. You could also rig up some sort of pigtail and plug it where the relay goes. I don't know which ones you'd plug it into but that could be deduced by looking at the schematic on the relay.
I would also check the fuel filter. |
Banned
The relay is a $20.00 part. I'd get one and swap it in... If things are better... you win.. if not, chances are that down the road, you will still need to update the relay and then, it's easy because you have on in hand.
