Olly's Avatar
Exclamation New Owner...
Hello,
As of 13 hours ago, I am the new owner of a 944. I have been looking at cars for many months, looking at everything from Mustangs to Pre-98 Super Beetles when I came across a car I couldn't pass up. I found a 86 944 with a broken odometer and no maintenance records whatsoever and bought it for $2k !!!!
I realize it was probably a pretty big gamble but now I am trying to figure out all of the maintenance things that I should do right away, not knowing any history whatsoever. Here is what I plan to do in the next couple of days:
- Change Oil/Filter
- Change Spark Plugs and Wires
- Put in a K&N air filter
Do you experts have any other suggestions or recommendations?
Also, there is some sort of a rattling sound coming from the engine... I was told it was probably a lifter.... Any suggestions there? Reading through this so-far extremely informative forum, I lookied at a post that talked about doing some ATF fluid. Would you recommend doing that to a 944 with unkown history anyway?
The last thing I was wondering about is a steering wheel shake past 50mph (the car doesn't). Not sure if that's normal...
Thanks in advance for your recommendations,
I love this car already and am making the girlfriend jealous...
Olly
'86 944
'01 Mitsubishi Diamante (not sure why)
Old 07-22-2003, 08:43 PM
SoCal Driver's Avatar
Replace the timing and counter balance belts.
NOW!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-22-2003, 08:59 PM
thamlin000's Avatar
yep....what socal said. broken belt=broken engine. do it this week.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 07-22-2003, 09:12 PM
Here's some stuff you may want to do:
http://www.geocities.com/MotorCity/1760/bought_a_944.html
A new fuel filter wouldn't hurt either.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-22-2003, 09:13 PM
For the steering wheel, try tightening it first. I think you'll need a 24mm socket and an extension.
'86 951 blk/blk
Old 07-22-2003, 09:17 PM
Steering shake is bad rim or bad tire or bad balance or all of the above.
Noise from the cam galley can be a loose cam gear. A single socket head bolt behind the rotor.
Old 07-22-2003, 09:25 PM
It's pretty manditory that you wash and detail it...
If you don't live life on the edge, you take up too much space.
Old 07-22-2003, 09:49 PM
Welcome to the board!
Yep - if you don't know when it was done last (and even if the Previous Owner "Claims" it was done, but can't preduce documents) change the Timing belt! It is the achilles heal of these otherwise excellent, nearly indistructable engines. Do a search for "timong belt" on this forum and see what we're all talking about.
I have documentation that mine was changed 2 years and only 3,000 miles ago, but because the car sat I am changing mine anyways. It can't hure to be safe...
Do you plan to do your own maintenence?
Good Luck with your new car! You made an excellent choice!
VT944
Brian
1985.5 944
Dodge Viper Blue on black/tan
white face gauges
throttle cam
short shift kit
Old 07-22-2003, 10:13 PM
MrPants's Avatar
http://www.connact.com/~kgross/FAQ/944faq.html
and really do the belts ASAP. its not something you can wait around and do next week. these do have interference engines so you cant afford to gamble.
how does the brake pedal look?
84 944 Non Alcoholic
Old 07-22-2003, 10:58 PM
stupenal's Avatar
I did a search for "timong belt" and i got nothing.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 07-22-2003, 11:35 PM
vott does ziss do?
ronin's Avatar
most important thing to do first...
sell it and buy a turbo
Old 07-23-2003, 12:45 AM
The vibration really could be any number of things. I would first be certain that it's really just the steering wheel and not the rotating masses up front (wheels).
If it turns out to be a real vibration from the spinning masses, don't worry, most of it can be address without spending more than ~$20-50 a piece on the following:
-Ball joints (late model needs a bit more work to replace)
-bushings
-strut tower mount
-bearings & seals
-rotors turned (while you're in there)
-new brake pads
Think of it this way, this type of work is fairly easy and would make for one he*& of an awesome afternoons work, all the while, building the relationship between you and the car...
However you begin working on the car, get some manuals and perhaps a parts catalog (I can help you get those).
Jake
1983 Euro 944 (Mine)
2000 BMW 323i (Hers)
1997 Sentra (unclaimed!)
Old 07-23-2003, 05:26 AM
MAS MAS is offline
Ditto what the others said... but you have to get the timing belt done immediately. If it snaps, the valve train (and maybe more) will be seriously damaged... and this will cost more than you paid for the car to fix.
Normally, the timing belt would have to be changed every 3-4 years. If the previous owner does not have records of something this important, it almost certainly means that this was not done anytime recently.
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 07-23-2003, 06:19 AM
Now you know why the 944 was $2k.
As all the others have said, you must do the belts and water pump.
Only use the Mahle oil filter. Change the brake and clutch fluid, and check under the pedals to see if the clutch master cylinder is leaking.
Nearly all "cheap" 944's need a $1000 or so to bring them up to usuable.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-23-2003, 08:13 AM
least common denominator
scottmandue's Avatar
[snip]
"Also, there is some sort of a rattling sound coming from the engine... "
and if that snowballs into $2000 or $3000 please don't post here re: These cars are crap!!!
Best of luck, hope you able to fix her up without too much investment.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 07-23-2003, 08:52 AM
seaboltman's Avatar
isnt the water pump supposed to be changed every 30k miles? Seems to me that you would want to check when it was last replaced, if ever.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 07-23-2003, 08:59 AM
vott does ziss do?
ronin's Avatar
no, the water pump should last much longer than that. Mine lasted about 120,000 miles
Old 07-23-2003, 09:02 AM
seaboltman's Avatar
hum... Ok well then i read some misinformation... Anyone know the average life of a water pump?
Old 07-23-2003, 09:04 AM
MAS MAS is offline
I agree, a rattling sound coming from the engine could easily be the bearings in the water pump... which means a new water pump is needed (if this is what it is).
Another (cheaper) possibility could be one or more engine mounts having gone.
-MAS
Old 07-23-2003, 09:13 AM
vott does ziss do?
ronin's Avatar
when my water pump went out, it sounded like it was trying to speak in complete sentences. the rollers also make similar noises when they get ready to depart this life. use the stick method to narrow down the possibilities.
Old 07-23-2003, 09:49 AM
