 " Oxygen sensor " Do somebody knows what brand are this sensors or if any model of VW have the same or compatible ? Thanks ------------------ 1972 914 v6 1974 914 2180cc 916 Look 1984 944 Auto 550 spyder (replica) My Page |
 They are Bosch and you can buy kind of a universal with the correct number of wires, 2, 3, or 4. drew1 |
 thanks Can you give more explanation. Eduadro |
 Eduardo, I was wrong about the number of wires. When I said 2, it should be one. The universal O2 sensors have one wire which is usually black for the signal. The other wires are for a heater to allow the sensor to come on quicker. On Porsche this wire would be green. On most universal sensors rhe heater wires are gray, I think. The 4 wire sensor also has a signal ground. I haven't seen a Porsche with these. The universal sensors don't have the right connector for a Porsche. This means doing some cutting & splicing or better soldering. I don't know if some of the VW O2 sensors use the same connector as Porsche. drew1 |
 When I had mine replaced my mechanic took a ford sensor and soldered it to the original Porsche harness. It worked great and cost like 35 bucks. |
 I paid $75 for the correct one for my car from Vertex, however, my mechanic said I waisted my money, as the universal Bosch sensor is the same thing....The universal is around $30 and is also available from Vertex...Cus |
| All times are GMT -8. The time now is 01:08 PM. |
