Post which is easier?
I am limited on funds and need to do 2 major bits of work to my 87 924s.
1. I need to replace the timing belt/water pump apporx. $800-900.
2. Full clutch job approx $1100-1300.
I am going to attempt 1 of these and have my mechanic do the other. My question is which should I do and which shoulod I have my mechanic do. I want to do the easiest of the 2. I have a compressor and most of the tools for either one. Are there detailed instructions for the water pump/timing belt change floating around out here? I have read over the clutch change procedure and it seems I could do that, but I don't really like the idea of working completely under a car on jack stands! I could do the timing belt w/out even jacking...correct?
Thanks for responses.
Jason
Old 03-27-2001, 05:15 PM
Post
Personally Id rather do the pump & belts
Old 03-27-2001, 07:04 PM
wolfrpi's Avatar
Post
Just do them both - they're a pain but well worth it because you learn much more about your car and save big $$$ doing it.
Erick
Old 03-27-2001, 08:49 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Post
Why is a clutch costing you $1300?!? Go for an aftermarket spring-centered clutch (forget those shoddy rubber-centered pressure plates) and with labor it should cost you under $1000. My mechanic is doing mine for $800, but he is a Porsche specialist and it was previously his car
Old 03-27-2001, 09:41 PM
Magnus_944's Avatar
Arrow
Click "944 Garage Shop Manual" at this site:
http://porsche-944-garage.tripod.com/
The pump and belt is not that hard, but it takes some time.
/Magnus
Old 03-28-2001, 03:16 AM
Post
My mechanic just came back at me today with a price of $1800 to do all belts/waterpump and a full clutch job. Should I just have him do it? This is about $300 more than I wanted to spend, but is it worth it to save my back and hands?
Old 03-28-2001, 09:21 AM
Obin Robinson's Avatar
Wink
we have a 1984 944 and it needs a clutch, and i am doing the belts and pump myself:
got the ENTIRE clutch kit for $300 from rennlist.com
got all the belts for $50
all i need is the water pump, and tensioner pulleys. (probably get from Hershey swap meet)
labor for clutch job: $500
labor for belts and stuff: $0 (DIY)
total investment for everything: under $1000.
time to get it all done: one weekend (clutch will be done on a friday, then belts will be saturday).
good luck!
obin
Old 03-28-2001, 09:24 AM
Blackfoot's Avatar
Post
jason, unless you're confident that you can do the work, have all the tools, manual/instructions, have the lift & space, i'd just have your mechanic do it all. $1800 for those items is a good deal (if you have a good mechanic).
Old 03-28-2001, 10:20 AM
Post
Mechanic is Porsche certified. I feel confident that I could both of these jobs if I had proper guidance. Clutch looks pretty straight forward. Just a ***** laying on the floor under jack stands!
Old 03-28-2001, 10:56 AM
Post
Jason, there's no reason you shouldn't be able to do both jobs. The clutch isn't hard at all, just time-consuming. You have to remove around 23,000 bolts. The timing is also easy, and not very time-consuming. Even the haynes manual covers both of these well enough. You gain two things by doing these on your own.
1 - You learn how your car works and how to work on it
2 - You would end up only paying around 500-700 dollars for both jobs.
Good luck and let me know if you need any help if you decide to do it yourself.
Dave
Old 03-28-2001, 12:09 PM
Post
Pump and belts is easier task. Just did mine.
Old 03-28-2001, 02:26 PM
