Send a message via Yahoo to asudds
8v Cam Shaft assembly needed ASAP
Can anyone help me... looking for a resonably priced Cam shaft ASSEMBLY
including good housing, cam, gear and etc. I have lifters. In and around
the Detroit area OR Canada to keep shipping costs down. If within a 3
hour drive I can dismantle myslef.
Aaron
Windsor Ontario
519-250-9119
atsudds@cogeco.ca
Old 07-24-2003, 03:19 PM
early/turbo or late...I believe there are 2 grinds
Tom
Early '85 944
Old 07-24-2003, 03:24 PM
1987 924S, so I will take any grind I can... I believe it would be the same as a late 944 NA or 924S
Old 07-24-2003, 06:26 PM
still looking
Old 07-25-2003, 11:33 AM
http://64.226.197.185/Paragon/Info/944_engine_identification.htm
I need an assembly for 1985.5 to 1989 8v NA engines marked M44-05, 06, 07, 08, 09 through M44-10
Old 07-25-2003, 07:37 PM
found a couple thanks to all who contacted me... both here and from Rennlist
Old 07-26-2003, 05:47 PM
doubt it would be an '89 NA (8v 2.7L 'big bore')...but if it is...the cam housing is different as well as the gasket...has to do with better maintaining a constant oil pressure in the camshaft housing with a oil pressure valve in the head instead of a check valve...similar to the 16v engines...the '89 cam housing p/n is 944.105.155.10
(if fact most everything is different on the 89 engine...except the look)
Tom
Early '85 944
Old 07-26-2003, 06:04 PM
