DME compatibility
someone told in a recent post that a 85-86 AFM + DME could be used in an early car to add some performance and upgradibility with a chip
only 85-86 DME's are compatible ? wich other years can be used ? any notion of compatibility of other MOTRONIC DME's used in BMW, OPEL , ALFA's , CITROENS ...... |
The newer dfm and afm can be used in the early 944. and much easier to chip it. They must be replaced as a set. FRWilk's site can give you more particulars of the enhancments.
Rick
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) |
I have been thinking of doing this myself. I couldn't find any info on FRWilk's site though on this swap.
Jack 86 Red 951 - Turbo Twists, otherwise stock for now 83 Black 944 w/86 951 front end - still down and out, but coming back slowly. 02 Altima SE 3.5 - grocery go-getter 00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi |
Early DME's. Late DME's 944S DME's, Turbo 951 DME's, 968 DME's.
Did I miss any model?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
If you were to put a turbo engine and trans into an N/A car, could you put a turbo DME on it and make it run good? Just curious....
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
I thought this was how it went Engine swap = dme swap on most cars (yeh, yeh, I know, these aren't most cars )
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
So can you put an later dme and afm on an early car?
If so what years are compatiable?
Texas hosts the 928 Owner’s Club OCIC in 2009 www.928ocicdfw09.com 1980 928 5 speed and a few mods.......... ![]() 928 OC member PCA member |
It wouldn't be cheaper if your dream was to rebuild a 2.5 L Turbo into a 2.8 L and you bought a decent used turbo engine and decent tranny. I have lots of dreams...
The best way to change the performance curves is to chip the DME. This will expand the torq curve and get rid of some of the bumps.
To use a late model DME with an early engine you have to swap the AFM as well.
I've done this to my '84, and it works fine.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
Hmm, so all I have to do is buy a late dme and afm,then I can chip.?
FRWilk has an adapter board for the early DME to allow plug in chips and couple of chip options for the early 944 that have received rave reviews
Tom Early '85 944 |
Yep. With a late DME and AFM you can run an aftermarket "performace" chip.
I was lucky enough to get a used DME with an AutoThority chip, and I have since accquired a stock chip plus a 'beta' version of F.R. Wilk's "Power Prom."
hope he didn't plug it in backwards
Tom Early '85 944 |
F.R.:
Yeah, I still have it. I ran it in the '84 for a while, but I have put that car back to stock so I can sell it. I have an '87 that I'm sorting out, and as soon as I get that finished I'll do some "chip swapping" and see what I get.
Fred, I am confused by your statement: "That is because it is the last thing anyone should be doing. I have helped people put early DMEs in 86s & 87s. This is me being serious."
Why is this the last thing people should be doing? |
so is it possible (easy ?) to do the swap ?
Porsche944 any details on your swap ? And why FrWilk says that it's the last thing people should be doing ? |
It's very easy to do the swap. I have posted the question to Mr. Wilk as to why he feels it should not be done. So far I have recieved no reply.
Remove original DME. Install late model DME. Remove original AFM. Install late model AFM. Adjust idle speed and CO (carbonmonoxied) level as necessary.
