-   -   Heater doesnt work!!! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12040-heater-doesnt-work.html)
85.5classic 03-29-2001 09:21 PM
My heater doesnt work, and when I turn on my air it stays on full blast whether i have it one high or low....What could it be?
Lawrence Coppari 03-31-2001 07:49 AM
Could be a number of things from a broken thermostat to a sticking control valve just in front of the firewall. The control valve regulates the amount of water from the block to the coil in the dash. I would suggest you start the car, make a mental note of position of arm on valve, change heater position and see it it moves. Check fuses and relays. I think vacuum controls the valve. Can't remember as I have not looked at mine in a while.
85.5classic 04-01-2001 03:16 PM
thanks, ill check that out!
