help identify this engine connector
Hey can any of you guys identify this sensor connector. It comes out of the engine harness at the rear knock sensor. I am installing a new (used) engine harness and the original harness didnt have this connector. I hope the pictures attach correctly.I am still trying to reach the seller to see what car this harness came from.
1987 944s 86k never too old to enjoy the performance of a fine auto
Old 08-03-2003, 07:15 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
It looks like a fuel injector connecter, didn't some of the 944s have a 5th injector somewhere? Anyone?
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 08-03-2003, 07:24 PM
Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
Some 924s and 944s have a cold start injector in the intake manifold, could that be it?
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 08-03-2003, 07:27 PM
This harness had to come from another 944S because it has the connectors for 2 knock sensors. As far as I know the 16v engine never used a cold start injector but thanks for the guess. Any one else?
Old 08-03-2003, 07:52 PM
SoCal Driver's Avatar
There are two plugs in that area that appear to be the same. One is for the DME engine temp sensor and the other is for the guage temp sensor.
The temp sensors are in the engine block to back of where the top radiator hose comes across.
I can't remember what the cam gear sensor plug looks like. I'll see if the manuals show anything.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-03-2003, 10:40 PM
Its hard to tell from the pics but I found the two temp sensors. One had 2 female terminals and the other had a fuel injector type of connector so those 2 are accounted for and the 2 knock sensors are accounted for and the air stabilizer conn. is on the line with the fuel injectors but I still have one extra connector that I cant account for. One of the wires is brown and the other looks like yellow with a black stripe. I looked at wiring diagrams for 87,88, and 89, 16v engines and I couldnt find anything. Let me know if you find anthing and if you need more pics let me know. I appreciate you help. Lonnie
Old 08-03-2003, 11:01 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Can somebody tell me what 944 came w/a 5th injector?
BTW, that looks like a temp sensor to me (DME).
Ahmet
Cheers!
Oh yeah the cam gear sensor is accounted for also.
Old 08-03-2003, 11:03 PM
the only other connector is the idle bypass valve. This is a servo type valve on the 944S's. The DME totally controls it unlike the early 944's where it just heats up.
Old 08-03-2003, 11:04 PM
1.2gees are you talking about a cold enrichment injector or is there something else
Old 08-03-2003, 11:05 PM
1.2gees's Avatar
As far as I know no variant of a 944 came w/a 5th injector, that's why I asked.
Is this a two prong connector or a 3 prong. There's not much else in that area, if it's not the temp sensor I would think idle controller is likely also. My experience w/the early 16v 944 engine is very limited, but I'm trying to help out.
Ahmet
Cheers!
Old 08-03-2003, 11:39 PM
This is a 2 prong connector. The seller said it came from a 88 944S but I still need to find out what that connector went to. Thanks for trying to help.
Old 08-04-2003, 05:52 AM
did anyone mention the tank venting valve? (violet / red-blue wires)
what color wires are under the gray sheath?
Tom
Early '85 944
Old 08-04-2003, 07:29 PM
Hey I checked the wires . One is brown and goes to terminal #42 at the DME. the other is white with a green tracer and it goes inside the pass compartment and comes out of the harness about a foot before the DME connector and goes into a flat black 8 terminal connector at terminal#5. When it goes through the connector the wire color changes to black with a green tracer and goes on into the car somewhere.
Old 08-05-2003, 05:00 AM
Originally posted by 1.2gees
...idle controller is likely also...Ahmet
I don't have any manuals here at work but IIRC the S has a 2 pin wire connector for the idle stabilizer while the others a 3 pin connector....just didn't think it went to the flat 8 pin connector though...I'll look tonight
Tom
Early '85 944
Old 08-05-2003, 07:11 AM
Hey I talked with Jim Burton the owner of Euro Werks Ltd. here in Charlotte and he looked it up in his factory Porsche manuals and said the connector went to the sensor for the Crankcase ventilation heater and since my car doesnt use that I dont need to worry about it. I think it only came on the 1988 944S. I highly recommend Jim to any one with a tricky Porsche problem. (704-882-6466 is his #) Thanks to every one who tried to help. Its nice to have people to talk to about these things. Lonnie
Old 08-05-2003, 04:22 PM
