Custom User Title
Big wooden boxes
I have to go back to my mechanics place and get my old transmission. I didn't realize quite how large it would be, or how dirty.
So- where could I get a big-old wooden crate to put it in to get it home (where I will slowly take it apart and learn how transmissions work and rebuild it once I get service manuals and the guts to try it and the space...) |
And get the hydrolic press and jigs and fixtures to set up the proper clearences.
Yeah, hydrolic is spelled wrong -- so what!
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Custom User Title
uh oh- sounds worse than I imagined. Maybe I'm kidding myself
vott does ziss do?
well, hydrolic I'll let you get away with, but clearences??? NEVER!!
You can't tolerance my clearences???
P.S. A local shipper like Roadway may have a pallet and crating service they use. Call around.
vott does ziss do?
AAAAAGH! The pain!! ![]() (excerpted from "101 ways to abuse an english major")
my favorite for trannys is the bottom roller piece of bread racks, often seen behind grocery stores, with a couple of cut to fit 2 by 12 wooden pieces. it makes them easy to roll under the bench, but can easily be rolled out when company comes over.
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Get the book "The Mother Tongue". Can't remember the author. I love to take an english major and have them write tech manuals. Grammar, punctuation and spelling are impeccable but their grasp of the technical side is at 1st grade level. If it wasn't for spelling checkers I'd be back at 1st grade level too!
vott does ziss do?
LMFAO, I guess I just might as well take the rest of the day off 'cause after this I ain't worth a damn.
Yeah, to some extent, what Hugh said.
If these transmissions are anything like VW Bug trannys, which they are.. It takes special jigs and skills to rebuild them. If you are wanting a tranny to tinker with and learn to rebuild, just go find you some ordinairy run of the mill 5 speed rear wheel drive tranny. The only special tools you'll need then will be feeler gauges, and maybe a gear puller(big hammer usually works nicely though). Or you can find you a bug tranny to disect, at least those are a dime a dozen, hell, even I have 2 of those ![]()
Jack 86 Red 951 - Turbo Twists, otherwise stock for now 83 Black 944 w/86 951 front end - still down and out, but coming back slowly. 02 Altima SE 3.5 - grocery go-getter 00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi |
